- Joined
- Nov 20, 2020
- Messages
- 2
- Reaction score
- 0
Today when we started the software, it doesn't appear but it's totally invisible!
It works normally, receiving and making calls but as I said, not visible.
I already tried to move the software using the shortcut Alt+Space then choosing "Move" and uninstall it and install again, restarted the computer but nothing solved the problem.
I'm using Windows 10 version 2004 and I can know which is the version of the 3CXPhone because it's not visible.
I'm sending two screenshots, one of them is when I stop the mouse over the 3CXPhone on taskbar and usually shows the software window, but in this case shows nothing. And the second screenshot is when I click on 3CX on taskbar then Alt+Space and select the option "Move" but the software doesn't appear.
