iOS app fails to dial contacts with + in phone number
it26
The subject says it all. I can dial directly with full number.
Do you have an outbound rule to match numbers starting with + ?
Created one for 12 digita and to strip one. Put at top of list. Thanks.
Does the 3CX Activity Log show that the calls do not match an outbound rule? (May have to set logging levels to Verbose.)
Does the rule you created, have + as the first character, or is it simply 12 digits?
Have you tried enabling/setting up E164, on 3CX, to deal with converting the + to the correct prefix, depending on the type of call?
asandris
