Solved IP blacklisted
jpalmer2007
My IP is blacklisted but I do not have access to the management portal. How do I fix this?
Try access from a different IP or wait until the IP got released.
Will the IP be released automatically after some period of time? Currently, I’m accessing the client portal through a vpn but that solution only works on some devices. I’m using Startup so I don’t have access to the management portal to remove IP addresses from the blacklist.
Access to the management portal is not available for StartUP instances.
The blacklisted IP will eventually be cleared, if you want to connect now you will have to try from a different IP.
Just ensure you are connecting to the correct URL and recheck your credentials before retrying (should be in your welcome email).
While registering Fanvil X4U phone on 3cx startup pro hosted version the system responds with SIP REGISTER FAILED and I get banned from 3CX console with IP Blacklisted message. Now I can access only with other connection with a different IP but it does not appear to be possible to remove banned IP from blacklist in 3CX hosted version.
Do you have any suggestions ?
Reactions: ASFH
I ended up doing a factory reset on my phone and then I updated it to the latest firmware. I had to wait 24 hours to try again because of the IP being blacklisted but this fixed it for me on the Fanvil V64.
Reactions: Rsztd and JohnS_3CX
Start your own thread, and describe exactly what steps you took to see if we can help.
AssurancePartners
