Solved Is cdr.log's format on v18 any different from v16?
davide.bonavita
Hi there,
as per the question in the subject, we use it to create some external reports in Domo. Will the update from v16 to v18 keep the same output fields we set up?
Thank you!
Yes, they should be exactly the same as in v16.
Reactions: davide.bonavita
Thank you for confirming that!
You're very welcome!
Jake R
