- Joined
- Sep 7, 2019
- Messages
- 16
- Reaction score
- 2
I have got calls from a strange number, and I am not able to identify from where it came in.
Is it a way to identify that?
| 11/19/2020 4:02:33 AM - [CM503003]: Call(C:394): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 192.168.1.8:5060 |
| 11/19/2020 4:02:33 AM - [CM503003]: Call(C:394): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 192.168.1.21:5060 |
| 11/19/2020 4:02:09 AM | 893191 | RGxxxxxxxxx | Not Answered |
| 11/21/2020 7:18:15 AM - [CM306002]: There is no valid STUN server specified! External IP can not be resolved. |
| 11/21/2020 6:58:15 AM - There's another STUN server that resolves to the same IP: 54.37.20.144:3478/UNKNOWN_TRANSPORT fk=0 tgt=; ignored |
| 11/21/2020 5:55:33 PM - [CM503003]: Call(C:409): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483 |
| 11/21/2020 5:55:33 PM - [CM503003]: Call(C:409): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 192.168.1.68:5060 |
This would be the last log (of a sequence, call # 409)) for that call.11/21/2020 5:55:33 PM - [CM503003]: Call(C:409): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 192.168.1.68:5060
No it was not terminated,This would be the last log (of a sequence, call # 409)) for that call.
Is the local IP of your 3CX Server 192.168.1.111, and the IP of extension 36, 192.168.1.68? Then it shows the call went to that extension, but does not appear to have been answered, it was terminated (for some reason), by the extension IP.
You should be able to work back, in time, in the log, and find earlier call 409 logs showing the call origination, the incoming trunk INVITE.
| 11/22/2020 4:57:28 AM - [CM306002]: There is no valid STUN server specified! External IP can not be resolved. | |||||||||||
| 11/22/2020 4:37:28 AM - There's another STUN server that resolves to the same IP: 54.37.20.144:3478/UNKNOWN_TRANSPORT fk=0 tgt=; ignored | |||||||||||
| 11/22/2020 4:37:01 AM - [EC100009]: External application [Hakadalexchange:0/PbxConfigTool] is disconnected: |
Date/Time | From | To | Talking |
| 11/22/2020 4:53:34 AM | +4790893xxx | VMail (33) | 00:00:14 |
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
