Is pro / enterprise required to make rules to bypass ivr?
oneBrainCell
New User
I was looking up how to allow contacts to completely bypass the ivr and some suggest using the call flow designer which is pro only.
Is there a way to do this with the free license? (version 18 hosted on 3cx)
Thanks,
You can make CID rules and use those to route calls as you want. This should be available in the free version.
Reactions: ChrisC_3CX
FYI - being 3cx hosted you can not use cfd, this is a limitation on 3cx hosted system https://www.3cx.com/ordering/pricing/hosted-info/
As above, you could use cid , or get an ddi number that you give out to route incoming calls differently
fngl
