is there a way to change phone call hang up sound?
ops.team.plasson
What is a phone call hang up sound?
Reactions: N_G
the disconnect sound you get when the other side hangs up the phone.
its played by your SIP trunk provider, or the actually other side
Thats what i thougt... Its has nothing to do with your 3cx.
so this is from our sip provider?
We only get this disconnect (hang up) sound only from the windows store 3CX app.
from our yealink phone we don't hear the hang up tone.
We only get this disconnect (hang up) sound from the windows store 3CX app.
When the SIP device you are using receives the message that the call has ended, then it will do (play), what it is programmed to.
If that can be changed, then it will be an option on each device.
x1515
