is there a way to lock my yealink handheld phone?
Song
One of the user want to know if there is a way to lock her phone when she is not around? Like maybe put a password on the phone so people do not just come up and can check her history calls. Is there a feature like that? Thank you
ok.. the yealink can do it. there is a feature in the yealink phone under features. Phone lock. My questions is if i change it in the yealink interface. If any update on the 3cx will it get wipe out? or only if i re provision?
Seems pretty simple to test no? Set it and then click reprovision.
Reactions: AWS2P
yes.. done.. fixed it.
ok. i was able to change the enable lock feature on the yealink phone. but for some reason it revert back to disable. is there a reason for this? I'm assuming maybe the phone got updated? please advise how to add this feature to the provision of the phone. thank you
bosdorf
