Is there anyway to have a inbound caller directly reach an extension?
NDCPS
For example, could someone call 555-555-5555#123 to reach extension 123?
Alternatively, is there a way to modify the digital receptionist to use three digits instead of one?
Thank in advance.
Within the digital receptionist, by default callers can enter a valid extension and get routed to that extension.
To test, when you connect the the Digital receptionist , dial an extension number
Users will not get any voice prompt about this, unless you record the message yourself
https://www.3cx.com/docs/manual/ivr-digital-receptionist/
Reactions: YiannisH_3CX
You might also consider subscribing to a DID service from your SIP provider. Calls could then route direct to an extension based on the PSTN number dialled. 555-555-5123 could route to extension 123
florentrobineau
