Solved Issue Accessing Webportal on Debian V18
2MT
Hello all,
I am having issues accessing the web dashboard after a fresh install of Debian V18. After the initial configuration, the system boots up to the screen below. I do not get the welcome screen like what is shown in the installation guide. I try to access the web dashboard to using the IP but to no avail.
Can you do me a favor and try:
• Redeploy using the 3CX ISO from the beginning.
• DO NOT select a static Local IP and use DHCP instead.
• Proceed with the installation and let me know if it works.
By the way, just to confirm, by "Welcome Screen" do you mean the following:
If not, are you perhaps referring to the 3CX Management Console or the screen showing you the Management Console credentials and PBX information?
That worked, thanks!
Reactions: ChrisC_3CX
Excellent! Glad I could help!
You can of course now manually configure your machines IP settings if you want a static local IP. You will have to access the Management Console and accept those settings in "Settings >> Network" after the change.
Don't hesitate to start a new thread should you need anything else!
