Issue with 3cx v18 Update4 Activation
gerdelaney
3CX failed to establish a TCP connection to activate.3cx.com.
Other OVH instances im using with the same settings do not have any issue with activation
I have rebuilt and restored but its not liking activate.3cx.com im able to ping it just fine
Hello @gerdelaney
If the phone system is currently on version 18 Service Pack 4, the activation issue is to be expected. Essentially you must update the system to service pack 5 in order for it to activate.
Hi thanks for the advice, the licence unfortunately lapsed over charismas break and has only been renewed the system as is wont let me update it is there any way to manually update
Hi @gerdelaney
In case you are not able to update the system from the Management the only option available to you now is to take a full backup, download the latest 3cx ISO from your portal.3cx.com, redeploy to a new machine using the latest 3cx iso, and restore the backup.
https://www.3cx.com/docs/manual/installing-debian-linux-pbx/
https://www.3cx.com/docs/manual/phone-system-installation-windows/
Additionally, we can advise moving the system to 3cx hosted where updates will be taken care of for you.
https://www.3cx.com/docs/switch-hosted-pbx/
Reactions: GeorgeP_3CX
GCLANtech
