Issue with call routing
steinpag
I have a our office hours set 8:00am - 18:00. what im trying to achieve here is our reception is available from 8-17:00 and during that time it goes to an overflow of people, for the last hour how do I get it to go ring the overflow group instead of reception?
Hi Steinpag,
You can use Auto Switch method on reception extension under Forwarding Rules, set Specific Office Hours from 8:00 to 17:00. Reception extension will switch to Do Not Disturb status after 17:00 and based on the status DND you can configure calls forward to overflow group.
What if after the hour of going to overflow we wanted it go to reception voicemail?
Hi Steinpag,
Can you share how your incoming call flow setup?
Assume you have set global office hours set 8:00 - 18:00, under inbound rules Destination for calls outside office hours can point to voicemail box for reception extension.
Remark
On reception auto switch scenario still working between 17:00 - 18:00
florentrobineau
