Solved Issue with Certificate Renewal - V18 Build 35
GH-JD
I was wondering if someone could help please?
The auto-renewal of the cert on our PBX doesn't seem to be working. I have rebooted the server and also tried to use the command that renews it but it still hasn't renewed.
under Settings -> Parameters
TEMPORARY_SELF_SIGNED_CERTIFICATE_GENERATED set the value to 1
If Windows:
Use CMD (administrator)
Run the following command:
"C:\Program Files\3CX Phone System\Bin\PbxConfigTool.exe" -renew-certificates
If Linux:
Login SSH as root
- su phonesystem
- usr/lib/3cxpbx/PbxConfigTool -renew-certificates
Wait about 5 minutes.
You may need to restart nginx.
service nginx restart
Reactions: NicholasP_3CX
This is a very important step in this procedure.
If Windows:
If Linux:
Login SSH as root
- su phonesystem
That worked perfectly. Thanks for all your help.
circusduck
