Issue with inbound IVR/Voicemail audio with SIP provider
NZRob99
Hi all,
We have an interesting issue with our SIP trunks. When we have 3CX set up to go directly through to a phone then we get 2 way audio and everything is OK. The issue we have is when the destination is to an IVR or a voicemail on the PBX then we do not have any audio. Changing the SIP provider and everything works OK.
any ideas?
Thank
Rob
Does you system pass the firewall test?
yes system passes firewall test, we have played around with PBX delivers audio and still having issues.
I'm assuming you aren't using a tested SIP trunking provider. So given that, I'd play with the 'Supports Re-invites' and 'Supports Replaces' options on the trunk
Reactions: YiannisH_3CX
Zexus
