Issue with recording Holiday Greeting
spreng320
We recently updated to version 16. Ever since the update I have not been able to update or record a new holiday greeting. When I click on either edit or add - I fill in the the appropriate info but when I go to hit OK - it is greyed out and won't allow me to do it. How can I get this to allow me to update or add a greeting?
Thank you
Karen
Hi Karen,
Can you post a screenshot of where you are doing this from?
Here is where I'm configuring it from, where the OK button is grayed out
12079
Have you tried changing the filename ?
Duplicate post
Firstly, you should use Chrome to run the management console. The other browsers are not guaranteed to work.
Then, please note that when uploading files they need to be in the correct audio format:
Format: WAV
Channel: Mono
Bit rate: 8 kHz
Sample: 16 bit
Not sure what the old format wav file is other than looks like .wav - but it won't even let me create a new one - with a new name
You people are awesome - I was using internet explorer - and tried in Crome and it now works! Thank you thank you!!!!!
Reactions: JohnS_3CX
You're welcome! I would recommend using Chrome for both the management console and the Webclient.
This is a fully supported browser.
jsbjsb
