Issues with iPhone App connecting to 3CX
DGZ
Hopefully I can explain this with enough details as it is a bit of a strange one.
Our 3CX is self hosted and working fine for all other staff. I now have two staff who when then open the 3CX app on their iPhones, it just won't connect. Both staff have just recently had their home internet upgraded from FTTN to FTTP (based in Australia). For Staff1, no change of any equipment, for Staff2, they setup a new modem. This is through Telstra using the Telstra Smart Modems. Have tested this with both the Gen3 and Gen4 modems.
This is the pattern of what is happening:
When at home:
If connected to WiFi network - 3CX shows Connecting... and nothing else happen, simple won't connect
if they turn off the WiFi at home and switch over to the 4G network, the phone will then connect
The Mail App connected to an Exchange server also does the same (not connecting) on the WiFi but does work on 4G network
All other app, web pages, speedtests, etc work on the phone when connected to the WiFi - just 3CX and Mail to Exchange
If they go to another location and use the WiFi there, 3CX will connect and work successfully - nothing changed on the phone apart from being on a different network so I know the 3CX app is setup and working correctly.
What we have tried:
* Turning off IPv6 on WiFi network
* Testing with a different modem at home - made no difference
* Disconnecting all other devices off the modem/WiFi - made no difference
* There are no VPNs setup on the phone to cause conflicts
* Remove the account and add it back
* Uninstall the app and add it back again
It is very strange that it appears to be something very specific to the base connection at the house as everything else has been changed for them.
I have had somebody recently suggest checking into the MTU packet size on the modem - has anybody had issues with this on their setups?
Dean
Hello @DGZ,
From your description, I can understand that this is a connectivity issue from the specific home network.
I would suggest running a capture from their modem, if there is access, and also contacting their ISP to check this.
The Mobile App uses HTTPS and port 5090 from the client to the PBX to see if there is connectivity.
I've ran into issues with comcast's DNS blacklisting our custom FQDN for the older customers (think pre-3cx domain availability I do believe), took down their entire office's ability to connect to the system. Had to put manual DNS entries in their local onsite servers to reconnect everyone to the system. In process of eliminating that headache permanently and moving to 3cx domains as time allows.
If you're running custom domain names, it might be on a blacklist with that ISP.
Hello @DGZ,
Thanks for the info, it is at the staff member home so I will try and arrange to get over there to do some testing. I have checked the firewall on the modem (as I have remote access to is) and even did a test with it off and still no connection. Will do a search on those two ports and see what I can find
Dean
Thanks for the suggestion, I will check with the ISP. Strange part is it connects OK at another location using the same ISP but with them, I won't rule out anything.
I think I am running on the 3CX domain - the phones have ourname.3cx.com.au listed as the server name in account if this is what you mean? I am still new to 3CX so have a bit of a learning curve to get past.
Dean
Several times we’ve seen Comcast router/modems block a specific IP and even IP: port, IIRC. Try just powering off their modem for 30 seconds.
Reactions: Colorado VoIP
comcast just lives in their own little world. but now realizing the OP is not in USA just adds to the mystery of what their local ISP is doing.
Check if they have Private Relay enabled on their iPhone
Hi guys,
Thanks for the suggestion but yes, not in the US - based in Australia. Have tried what you both have said but no luck there
Dean
I have checked and they are not using Private Relay - they don't have the iCloud Subscription.
Thanks for the suggestion though - it is going to be a crazy small setting on this one!
Dean
I have managed to get a bit more testing done today and it is still blocking but when checking the settings on the modem, it does have a voice configuration active with SIP configuration set to port 5060. Unfortunately, it is not possible to turn this off as the settings are locked and not able to be edited or disabled.
If the modem does have it's own SIP on this port, I am guessing this might be what is blocking the 3CX app from getting through?
Dean
Although this is not the good solution, even if their IP addresses are not on the blacklist, temporarily add their Public IPs to the 3CX whitelist and ask the users to check whether they can connect now.
If they are able to connect, it would strongly suggest that, despite what was mentioned, they may be using a VPN connection on their mobile devices, or simply connecting from an IP address that 3CX does not consider trusted.
If possible, avoid leaving those IP addresses permanently whitelisted.
They could be shared public IPs that are also known to be used for malicious activity or attacks.
Guillaume
Reactions: paulodagraca
Guillaume
Hi Guillaume,
Thanks for the suggestion - I will check into the IP addresses and try setting up the whitelist for them (temp based). I was able to get onsite yesterday and tested with my own phone (so to avoid problems with the staff not knowing if things are on or off). Had exactly the same issues as the staff - when I connected to the modem - no connection. I am thinking there is an issue with the SIP settings in the modem which might be blocking the 3CX connection but I can't turn off SIP.
Dean
Hi Guillaume,
Dean
SIP hasnt anything todo with the connection to the pbx. The app on the phone is using https and 5090 to connect.
Reactions: NikosT_3CX
Thanks, appreciate that - I would have gone down that rabbit hole for a while. I will do a bit more searching on those two ports to see if I can find anything that explains this. I am waiting on one of the staff member to test a different modem to see if that makes a different - although not SIP as I thought, there might still be another block I need to work out. Will see if I can get some exception rules for 5090 and https out of the modem (although the firewall is set for all traffic LAN->WAN to be allowed).
The really strange part is the modem has a backup which uses the 4G mobile network and when I force this on, the connection works - it is only when running through the NBN (Australia's fibre internet system) through the modem it fails
Dean
Just wanted to add a bit more information here
I tried adding the IP addresses of both staff member to the whitelist in the 3CX console as per Guillaume's suggestion but that did not help.
As another test, I tried to access the 3CX web console from a computer in the same network - it just opens a blank screen, takes ages and then shows a reconnecting message at the bottom but nothing happens - I can't even get to a login page.
I am waiting to hear back from one of the staff who is going to test this with a non-Telstra Smart Modem as I am thinking there is something very strange going on with that modem - will post an update once I have heard back from them.
Dean
Dean
Are you running any geo-blocking / IP filtering on a firewall in front of 3CX?
Hi everybody,
Sorry for the delay in this, had to try and get testing done and wait for people to get back to me. Rather than wait longer, I setup the system myself to do testing.
I have contacted Telstra (our ISP) and they claim nothing wrong on their end and that 3CX might be blocking Telstra for some reason? No idea what they would be.
I have tested it on two separate modems in my office, with my own gear and when connected to the Telstra FTTP connection, 3CX app won't connect on my apple devices and also I can't access the Web Client page on my laptop. As soon as I connect to a different ISP, all devices work correctly. I have turned off firewalls, added whitelists, changed SIP settings - nothing seems to be working for me.
At this stage, I am going to say there is an issue with the ISP as I now have another system not working using the FTTP connection but is working on all other connections. Proving this is going to be another story.
My thanks to everybody for you help and support on this one but I am going to call this a "not-3CX" issue.
Just as a side note:
I am no expert on this so for tech people out there, when I run WireShark, on the Telstra connection, the main difference I can see in the logs is the Conversation completeness is showing as Absent and there is an entry under TCP analysis flag saying "This frame is a (suspected) retransmission) on Telstra but on the other ISP the Conversation completeness flags are showing as Present and the TCP analysis flag is not present.
Dean
@DGZ
Where did you run wireshark ?
The best is to run it at the same time on the Telstra router and on the PBX side.
So then get them both and open them side by side.
On the Telstra pcap, search with the public ip of the PBX " ip.addr==x.x.x.x "
On the PBX pcap, search with the public ip of the remote location where you have the Telstra router.
Compare the packets and check what leaves and what arrives on both sides.
You can add more like " tcp.port==5090 " which is the port where the 3cx client connects to the tunnel of the PBX.
And also " tcp.port==5001 " which is the port where the 3cx client connects for Presence.
So you can do something like this " ip.addr==x.x.x.x and tcp.port==5090 "
cvanderzwan
