Issues with M-Net SIP outgoing caller ID
noobienat0r
we switched to m-net sip. Everything is working fine except outgoing caller id. its always unknown/anonymous caller id.
I already setup outbound caller id for each extension and each phone, to a primary phone number. I tried to change the outbound parameters at sip trunk configuration, but nothing changed, its still unknown caller id :(
Please help
Have you tried talking to m-net sip to see why that is happening?
they told me that on their side everything is fine
And they are correct. But you aren't asking the right questions. The question is where are they looking for caller-id. Caller-id can be sent in a number of fields so you need to find out which one they are looking for.
ok, i will call them in which field they are looking for the caller id
Once they do, as long as it's one of the fields on the outbound parameters tab it's merely a matter of changing that to reflect your desired caller-id.
Hi @noobienat0r
As m-net is a supported provider make sure you are using the default template included in the PBX. Outbound caller ID should work with the preset settings.
[email protected].
