IVR is not starting after update to Debian 10 Alpha 18
ECOM GROUP (Mauritius)
I just upgraded to Version 18 Alpha (Includes OS upgrade from Debian 9 to 10) , Update took forever , after 2 hours, i had to reboot the system and i can login to management console, but 3CX PhoneSystem 01 IVR Server remain stopped. I tried to restart and no luck. The only way is to re install the ISO Debian 9 and restore backup from previous Debian 10.. previous installation was Debian 9 then updated to Alpha V18 to Debian 10 without no issues. I decided to wipe 3CX completely and re-install from Debian9 ISO, and restore backup without issues. Then Issues comes when updating again from Debian 8 V18 Alpha. Can someone help?
License: Pro Annual: 16.0.9
Machine: Mini PC Debian 9
Distributor ID: Debian
Description: Debian GNU/Linux 9.13 (stretch)
Release: 9.13
Codename: stretch
Hi @ECOM GROUP (Mauritius),
When you say you tried to restart the IVR Server, what steps did you follow to restart it?
Hi Vasilis, Thanks for your response, i restarted it in management console service and also via 3CXStarServices command.
If no luck, i will need to doanload 3cx debian 10 ISO 10.7.0.
Is there a fix for my issue?
BIT Incorporated
