Solved IVR to Ring group/queue/digital receptionist or can ask direct extension number
Effervescence
Trial User
I want to set an IVR that can route a call directly to a queue, ring group or digital receptionist. Also, a caller should be able to dial an extension number directly to reach the extension. How is that done?
Have you checked the guideline?
Hello Yes,
But will it ask for the extension number by default or i should set that? The probem is I want it to have an option to ask caller for the extension number they want if they know it
This is something you need to include on your custom prompt.
For clarification, in short:
-I need to create a digital receptionist with a custom IVR prompt
-I can assign options 0-9 as I wish to-If i include , press the extension you wish to call, If the user presses the extension number it will ring directly
That is correct
RJenkinsROCK
