Jabra and PWA
Tyler.Calhoun
Trial User
Hello all,
we have a little problem with the PWA app. Sporadically we can not accept calls through the headset.
Do we need another driver? Jabra Direct or the ChromeHost?
You should actually not install anything, if you have any of the two already installed do, do proceed with completely removing/uninstalling them and reboot.
Also, just to clarify a bit:
• You mention the PWA, does this happen with the webclient(without PWA) and desktop app?
• Do you have more of the same headset on other PCs, does this happen their also?
• If not, can you connect this headset to another PC, dies the same happen?
