Journaling without CRM integration Wizard
Cinosarge
New User
Theoretically asking: is there any feasible way to export data from 3CX, in particular reference to journaling, to a custom CRM without using the template XML integration?
Using the CDR, that's the only other way. Why not use the CRM integration? It can work even without a contact record, if that's the issue.
Reactions: edossantos
