Solved Just set up phone a couple days ago, all of a sudden very erratic, doesn't work
survivalbloke
I've got Telnyx as a trunk and 3CX as a pbx, and the system is hosted with 3CX. I just set up my first, one and only phone, a yealink T33G and it has worked great, until a couple days later which is today. I've reset the phone, restarted the SBC, I'm at a loss. Nothing has changed on my end - nothing.
What can I check? Thank you so much in advance.
Please note that there is an issue with Telnyx as we speak.
They are experiencing a DDoS attack and this is what is causing failed calls, API ,portal latency/time outs and/or delayed or failed messages.
Please check below link:
https://status.telnyx.com/
OH MY GOSH! That's the problem then - I'm certain of it. Man. So the whole reason I didn't go with Voip.MS is because of fear of DDoS and the problem they had a few weeks back. Now Telnyx? Should I be worried about my choice in SIP trunks?
Indeed other providers were in a similar situation a couple of weeks back, hopefully the issue with Telnyx will be resolved soon. They already posted that they partially restored their services so I would keep an eye on their status page.
apbGroup
