Solved keep alive in 3cx
Huseyn_17
What is and what can be reason to enable keep alive function in settings > network > firewall ?
Thank you.
Its normally used to keep NAT port mappings alive. Not really required if you've set up your static mappings correectly.
https://www.rfc-editor.org/info/rfc6263
enable applications using the Real-time Transport Protocol (RTP) and the RTP Control Protocol (RTCP) to keep their RTP Network Address Translator (NAT) mappings alive.
Specifically it will have your PBX send a few UDP packets from its SIP Port to the SIP providers every so many seconds. As @kieferschild mentioned though, it should not be required if the firewall is configured correctly.
Reactions: Huseyn_17
Thank you!
Reactions: ChrisC_3CX
You're very welcome! Feel free to start a new thread should you need anything else!
mazet
