LetsEncrypt with custom FQDN (Debian ISO)
Basetek
Hi Folks,
This seems to come up a lot and found myself needing to do the same. We run V16 on Debian 9 ISO and it turns out it's super easy:
  1. SSH to your PBX
  2. Install Certbot:
    Code:
    apt-get install certbot
  3. If your PBX lives behind a firewall make sure you forward port 80
  4. Manually request your SSL certificate without an installer:
    Code:
    certbot certonly --standalone -d example.com
  5. Edit your nginx config to point to the certificate files:
    Code:
    nano /etc/nginx/sites-enabled/3cxpbx
    ssl_certificate /etc/letsencrypt/live/example.com/cert.pem;
    ssl_certificate_key /etc/letsencrypt/live/example.com/privkey.pem;
  6. Reload nginx:
    Code:
    systemctl reload nginx
That should get you up and running. I also added the following to the [renewalparams] section of the certbot renewal config file /etc/letsencrypt/renewal/example.com:
Code:
deploy_hook = systemctl reload nginx
This will reload nginx after a successful certificate renewal.
HTH, Richard.
I've done the same, but let's encrypt is timing out. Spent way too much time messing with it. Did you have to add any locations in nginx for .well-known?
Wecare_ITA
