License key has been revoked.
[email protected].
Forum User
Your Subscription expired on 31/03/2025. Without subscription you lose access to important features
Trying to relicense and when try to renew says cannot find the subscription
Any assistance greatly appreciated.
Please do not post your license key in the forum for everyone to copy. We will look into it
Is this a V18 system? Can you tell us the exact version of the PBX?
Yes, it is a V18 system.
18.0 Update 9 (Build 35)
Thank you
Please note that your key has been revoked as it was a free edition key. We sent out multiple emails regarding this prompting users to upgrade to V20 prior to 31st of March.
Since the key has been revoked your only option to continue using the system is to buy a new commercial key and use the replace key feature to reactivate it. Then you will also able to upgrade to V20.
We didn't receive the email notifying us of this, can you confirm the email it was sent to?
The system is only used by 6 users, how can we downgrade once a new licence is purchased/? or can we use a trial version?
I have sent you a p.m. with the email address the emails were sent to.
If the system is only for 6 users then I would recommend moving them to an SMB system which is free and will cover the needs of 6 users
Great how can we do that? apologies I am a bit new to 3CX
You can create a Free installation from your customer portal. This will generate an SMB free instance for you. You will need to reconfigure your users there and start over.
Where do we go in the portal to create a free installation? Just looking at it now.
No, you need to login as customer to create one. The free ones dosnt make any sence for partner.
You might get better insight be contacting customer service at https://www.3cx.com/contact/ , but in general, no, the free licence is for direct users.
That's a shame, we have a few customer leads of 1/2 users just wanting a really basic system. Seemed like a good solution for it.
No members online now.
RJenkinsROCK
