License transfer from v18 to v20
nazaret
SOHO User
I have v18 3CX PRO 4 SC which will expire June 2026, it is hosted on AWS
I have installed v20 Lightsail but it is 3CX PRO 8 SC and the trial will expire Sep 29
I have finished with v20 setup and it is now live.
No option to downgrade to 4 SC, if I just replace the license key will it be downgraded automatically?
Should I first delete v18 and then replace the v20 license?
Please use the provided form to contact the relevant department in 3CX to request further information.
Thanks Charles, can you please clarify what you mean by "the provided form"?
RJenkinsROCK
