Solved License
mji
Dear All:
We have downloaded 3CX software PBX and installed it. We would like to started the free license first. However, when we check the license it indicates it will expire in 39 days. It really confuses us. Can anyone tell us why it is so?
Minda
free license is 40 days PRO trial first then revert to STD, no matter you got warning in39 days your licence just will become STD and loose PRO features.
Hi, aws2p:
Thank you so much for your kind help! Do I need to do anything to revert to STD version? How many simultaneous outgoing calls we can make then, 4 or 8?
Minda
nothing to do, just don't care about email saying license ends . SC stay as is for almost first year then it revert to 8SC
Thanks a lot! What does 8SC really mean? 8 simultaneous incoming and outgoing calls? How about extension calls extensions?
Minda
everything count for SC , incoming and outgoing calls , internally, when you stay on MOH in a Q etc....
Two ends connected count as one SC
Even internal communication between 2 extension counts as 1 SC?
Just going back to this licence query, but am I right in saying that 3CX are giving away pro licences for a year? If so, how do you upgrade from standard to pro?
No free license is 40 days trial PRO then revert to STD until 3 years , so if you stay with free version you have nothing to do , if you want to keep PRO features then you just need to upgrade from STD to PRO
Reactions: Lusk
EMMEPICASA
