Solved linux install on HP Mini
VictorC
SOHO User
Has anyone installed on a HP 260 G2 Desktop Mini PC?
I run the installer and it comes up with a message that it need non-free firmware files.
Missing rtlwifi/rt18723befw.bin
So are you saying it's stopping you from installing or...? Do you need WiFi?
Hello @VictorC
Is the linux installer halting or the PBX installer?
fixed, it was looking for drives for something used on the MB, disabling that fixed it.
Glad to see the issue has been resolved and thank you for updating the thread with your solution.
cmedina
