Live Chat Web Flow Integration
mnl_hash
hi
has anyone tried integrating the webchat in Webflow?
we are having trouble getting the code to work. Any suggestions?
Hi @mnl_hash Can you expand on the issues you are facing so that we could offer some suggestions?
this is the console log provided to me by the developer of the website on webflow, i have just x'ed out some info, however you will be able to see the log msg, also to add i am using pro version hosted with 3cx
Access to fetch at 'https://XYCCO.my3cx.ca/MyPhone/c2XXXXXXX=LiveChatXXXXXX' from origin 'https://iXXXXXXX.ca' has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource. If an opaque response serves your needs, set the request's mode to 'no-cors' to fetch the resource with CORS disabled.
XYXCC.my3cx.ca/MyPhone/cXXXXXXX=LiveChat99595:1 Failed to load resource: net::ERR_FAILED
Reactions: Dmitry Yurkin
Hello, did you add specified "'https://iXXXXXXX.ca'" as web-site address in livechat configuration form?
The answer to your specific question may depend on your exact use case.
Figured it out .. we flow is blocking it on their end .. need to update plan with them .. thanks for the response everyone
SupportRock
