Logrotate 3CXConfService 3CXTunnel Logs
epress
Firstly I would check a few things as I have never experienced such an issue.
* what mode is your logging set to? Verbose, low etc.
* are you using any unnecessary resources on the server, such as storing call recording direct when you don't have to.
* does your server comply with the supported hardware specifications outlined by 3CX.
1)i've verbose logging active but only with these 2 logs i have this issue.
2) Yes my server complies 3CX hardware specifications.
You should not have Verbose logging enabled constantly it does put a bit of extra strain on the platform.
Other things that would do this are "PBX Delivers audio" on extensions and call recording (which also requires audio to traverse the PBX).
@eddv123
I'm confused on your answers here. The OP is asking about log rotation and your responses seemed geared towards resource utilization. Perhaps you mixed up threads?
@epress
It looks like 3CX just missed including those logs in their rotation strategy. I remember reading that thread when it was first posted but never followed up myself. Not sure why it was closed. I'll check a couple instances we manage to see if we are seeing the same behavior.
@eddv123
@epress
Thank you very much @cobaltit, i'll wait your result.
I've noticed this behaviour since SP6, because in previous SPs i've never had log issues.
Sorry forgot about this. I'm travelling atm so I'll check early next week when I get back to the office.
BIT Incorporated
