Solved Logs are full of "Extension XXX registered/unregistered"
Matt Nelson
Logs are full of registered/unregistered entries all day long (every few minutes) for all extensions.
How do I resolve this problem?
Any help would be greatly appreciated! Thanks!
Hi Matt,
Obvious bit out of the way first - your extensions are having registration issues :)
Can you see this one the endpoints themselves - most will have a little phone icon which will change when in a registered/de-registered state.
Also where are the phones located in regards to 3CX - local or remote via SBC/STUN or VPN connection?
Running a PCAP trace from the end-point would probably be a good start I think.
This is most likely users mobile apps reregistering.
Reactions: Wendelspanswick
Also Web Client extensions as well, we have a number of extension configured just as web clients to act as wallboards and the log shows them as pinging in and out all the time
Hi Matt,
These are all soft phones: 1 on an android device, 1 on IOS, and 1 on a Macbook Pro.
I use the phones in my office (LAN) and when out of the office (WAN). I will be deploying IP phones shortly on the LAN.
I don't see the status changing on the devices themselves - I don't spend too much time staring at the display, but I'm certain I would have noticed.
This does not appear to be causing any noticeable issues at the moment, but I am planning to move my business numbers from my virtual PBX (grasshopper) to my 3CX system shortly, and I wanna make sure I can rely on this system. I suppose what I'm trying to say is... is this something that I should be concerned about and will it cause problems at some point? I'm new to the system so this caught my attention considering it seemed like unusual behavior. I need the system to be as reliable as possible (who doesn't lol!).
Would love to hear your thoughts.
Thanks for the help!
As you say they are all soft phones - see the point made by @Rhys Haskell previously.
I would expect this behavior from mobile clients (Android & IOS) but not Window or MAC.
Mobile clients will most likely be changing connection type from 4G to WiFi regularly and during this process will have to go through the re-registration process again due to IP changes, desktop clients are static so I would hope not re-register too often.
Also when you close a mobile app it deregisters until it is activated by PUSH again. This is normal behaviour and I wouldnt be worried about it.
Thanks for all the responses. I will consider this closed, and a non-issue at this point. Thanks!
Rich Hopkins
