M365 Sync Only - Unsorted and Unsortable
jameshs
Good Day,
We only sync some users to M365 with 3CX, however the Sync Users -> Sync Only list appears to be in random order with no way to sort or filter it. If we want to remove one user we have to go through 12 pages of entries reading each one to find the user to remove.
Does anyone have any suggestion on managing M365 users? We would love to control sync based on Group membership but there seems to be no way to do this. At this stage we would just like to be able to easily find the name of the staff member who has left so we can remove their account sync.
For background we are a school so only want to sync staff accounts and not create 1000+ student accounts. Would be very easy with group membership but...
Apart from doing CTRL + F and searching, no.
However, and try at your own risk.
If you set paramter DEVELOPMENT_DNTABLE_EXPOSE to 1 you will get an extra property tab.
Select the extension you want to remove and then search for azure and remove the 3 properties.
/dev/simon
