Making and receiving calls
WarriorMaurice
Good day,
I have added a SIP trunk and it is showing registered. I can make calls from the app, but no one on either end can hear each other. Also, when I try to dial the SIP number given, the call just ends without ringing. Is the issue on the SIP provider's side or 3CX?
From what we can see, the trunk and all its settings are correct. Please check where you are routing the calls within the admin console > Office hours >Where to send calls and messages section.
If this is all set correctly, you can contact your VoIP provider to check further.
The office hours is set and the calls route to the ring group created. The SIP number has been assigned to the ring group. I think the issue is on the provider's side.
albertpugo02
