manual Google Workspace integration
narkuma
Hello!
we would like to integrate google workspace, but we would like to create the google project ourselves.
We have our own way to manage our projects and our engineers do not like to drop a super admin password to a wizard without knowing what it does.
How can we do the integration without the wizard?
cheers
Marius
P.S: Could not find a google category in the forums...
Hi Maurius, if you want to make the integration with the google workspace you have to do it via the wizard, there is not any other alternative about it. The official and supported method is described in this guide https://www.3cx.com/docs/manual/google-workspace/
Hi @narkuma ,
As @Alejandro_3CX says the official and supported method is the wizard based one.
Now if only a limited and specific usage is needed, we have some guides that show manual steps for those, with the strong recommendation to use the wizard whenever possible.
https://www.3cx.com/docs/google-cloud-storage/
https://www.3cx.com/docs/manual/google-speech-api-v2/
https://www.3cx.com/docs/voicemail-transcription/
https://www.3cx.com/docs/manual/google-sso/
https://www.3cx.com/docs/google-bigquery-configuration/
Kayla Norris
