Mass update extensions via csv?
ElementalWindX
Is it possible to mass update extensions via csv? IE I want to change the outgoing did on 60+ phones to several different DID's, I export the extensions to a csv, I update column BF with the proper DIDs, save CSV, and import that CSV.
When I do those steps, it says the extensions already exist and errors out. Would be nice if it would just update with the changed data.
Is there still a way to do this process?
It appears I can delete all the extensions and reimport them, but will I have to reprovision all the desk phones? Or will they be ok without any need to touch them?
Thanks.
Reactions: Ronald Lysmont
Your kidding.. This isnt a feature?
arming
