Metered Sip Usage ?
Usama Asgher
Forum User
We need to limit metered use of sip for specific users. Most users will use their extensions to make in bound calls. Is it possible meter sip usage ?
There is nothing native that will set a time limit for users, specific or otherwise.
Hi @Usama Asgher,
As @leejor has pointed out, there is no native way to do this in 3CX. There is a maximum call duration of 3 hours for security purposes.
You may want to speak with your provider and see if there is anything they could do on their side. Other than that, there may be a possibility of a partner writing a custom integration if all else fails.
Reactions: Usama Asgher
BIT Incorporated
