Solved Microsoft SSO not working
lritpeter
After upgrading to V20. The option to sign in using Microsoft SSO is no longer working. Any one have any ideas?
Hi did you check if the user has enabled the SSO option:
Try to reprovisioning the O365 as mentioned here and try it one more time.
Yes, I have already tried to reconfigure O365. Yes I have confirmed O365 is enabled for each user.
You need first to configure the O365 integration and then enable the SSO option for the users.
Yes, I know. That is what I did. It is not working. More so, it was working on v18 and stopped working after upgrading to v20. I have also tried to remove the 3CX app from O365 Ent Apps and reconfigured from scratch. That did not help either.
Have you disabled SSO first, then re-configured the integration and still experience the issue?
That did the trick! Thanks!
cur_cb
