Migrate to Self Hosted 3CX from Startup
mrbryce2000
New User
I am using a 3CX Startup system for my home phone number. It was a good start, but now my needs have exceeded what Startup can provide. I've spun up free self hosted 3CX instances before in AWS. Is there a way to migrate from my Startup to my own self hosted 3CX? The SIP trunk I'm using is labeled as for use with Startup, will that be an issue?
Thank you for your help.
Please note that StartUP is the only free offering tho. You will need to buy a Pro license and host it somewhere (even if with 3CX.)
And no, there's no way to transfer/backup/restore, you'll have to setup from scratch.
Yes your SIP trunk should work on self-hosted if it was supported on StartUP.
Reactions: EddieO_3CX
As stated in the reply from ConceptsWeb, please note that there is no way to migrate from the StartUp to 3CX Dedicated, at least not at this time, also the SIP Trunk would work in the StartUp and Dedicated (hosted or self-hosted). You may want to sign up for the 3CX Dedicated Pro or Enterprise license.
Netflo
