Migration to Multi-Tenant
M4rtin1
SOHO User
No, you need to start from scratch
Reactions: N_G
@M4rtin1 It's possible to export a user list, change the department and extension number, and import. Presumably extension numbers will change, or at least they can't overlap ranges.
Are you a partner? MT is generally meant for partners AFAIK...
swegner
