Misleading/confusing call stats in reports
NiallB
Hi folks,
I've been trying to put together some reports for management on the performance of our helpdesk call answer rates, and came across something strange. The "Queue Answered / Unanswered Calls" graph flagged one day as having 45 unanswered calls vs 40 answered. On drilling down to the hourly reports for that day I got the following graph:
I then tried to get a report of all calls that went to the Helpdesk queue (xtn8000) and got this:
How is the system reporting 9 unanswered calls when there were only two calls that hour?
The queue has 1-4 agents signed in at at any time depending on breaks/meetings, is using Polling Strategy: Ring All and goes for 15 seconds before retrying - is it registering multiple attempts to call each agent before one of them picks up?
Any help or guidance would be appreciated so I can put together some useful reports.
The bracket for the 5 answered calls and 9 unanswered calls is between 12PM - 01PM, not the 1PM - 2PM you searched on.
Kind regards
Well, that makes more sense then - thanks for the clarification!
Having pulled the correct stats I can see the 9 missed calls, but it is only actually 7 callers (well, one person five times - thanks for messing up our stats, pal!)
Our call flow sends incoming calls to the "Helpdesk" queue initially and then to an "Overflow" queue if not answered within a fairly short window. If a caller gets put through to the second queue before hanging up, 3CX is counting that as two missed calls. Is there a way I can configure the call flow to give more accurate stats while still maintaining our overflow functionality? We're on V16.0 update 4.5
travislogixal
