Missing call ID CRM field
rlg
Gold Partner
Hi 3CX Team,
We miss a field in CRM integration, reprensenting the call ID, such as @CdrId and / or @CallHistoryId.
So that we could join with other data sources, such as raw CDR files, or cdroutput table.
This could then also be used as a key for a CRM database integretation.
Could you then consider this please, as you already did for other variables (such as this one) ?
Thank you very much !
Perhaps post this as a suggestion in the Ideas forum , if you don't see it there already.
Hello @KyriacosS_3CX,
Thank you for your reply and suggestion, just done here.
Thank you again !
Reactions: KyriacosS_3CX
Kayla Norris
