missing "integration" setting
anoushow
as i was trying to trigger inbound call with an external url, i've found multiple post pointing to set it under setting > integration (web client)
but i don't find how let this option appear under my settings
thanks
Anoush
Are you perhaps using a Standard 3CX License? You can check in the Management Console under "Information >> Product".
Yes i have a standard licence. because i've tried to install a "crm integration" in admin console and found option to enbale integration in user (but check mark is disabled)
So i suppose i don't have chance until upgrade/self install?
It's only available on Pro/ENT editions I'm afraid so that's why you don't see it in the Webclient at all.
megalmazan
