Missing VoIP Provider Checker after installing v20.0 Update 8
IT Dept
SOHO User
We are using 3CX on prem. I just installed Version 20.0 Update 8 (Build 1109 Release) but there is no VoIP Provider Checker as stated in this article VoIP Provider Checker.
Is someone else experiencing the same issue?
Regards,
Martin
@IT Dept if you login in Incognito, do you still have the same issue ?
Also the trunk you are using is with a 3cx template, or an imported ?
Reactions: KyriacosS_3CX
This is what you should see from the Voice & Chat page:
What do you get?
Thank you both.
I tried with two different browser and in Incognito mode I was able to see the "Check SIP Trunk" option. Then deleting the history and login normally I was also able to see "Check SIP Trunk" option.
Thank you again,
Martin
LeeonLau
