Mobile App Timeout Feature
Netmatters
Platinum Partner
We understand there is currently a timeout feature on the mobile app, in that users are timed out from the mobile app, we understand the reason for this is that default PUSH will expire after 7 days of inactivity, and in order to refresh you need to re-open the 3CX App.
Could it be put in the product/software pipeline for there not to be a timeout feature on the mobile app?
Dont know if its available for iOS but for android there is the "keep active" option, might be worded differently my app is in Dutch.
Currently this is the default behavior and cannot be changed or modified.
You can post your idea however i don't think this will change. Keep in mind that the "Keep Alive" option in the Android App is a temporary solution when there are connectivity issue as it is battery consuming.
Senergia
