- Joined
- Oct 13, 2018
- Messages
- 233
- Reaction score
- 9
Hello all 3CX experts;
I am trying to configure my 3CX server to allow register mobile phone outside the LAN, the iphone and the android phone works fine with the 3CX app while using at LAN. When try to use through cellular network or from home wifi network, it is not able to registered the phone. I saw the following logs from the Dashboard.
The firewall check on 3CX server is success, all "Green" light except the "detecting SIP ALG... not detected".
The "Disallow use of extension outside the LAN (Remote extensions using Direct SIP or STUN will be blocked)" in Options of the extension is not enable.
The necessary tcp / udp ports are open subject to the 3CX sites.
What else should I check?
thanks!
- SIP Server/Call Manager ID: 4101
Extension 29920 is unregistered, removed contact: sip:[email protected]:5060;rinstance=0-phjxkzygitm5xltfjbgwzypugtbvevjw;inst="799563", received from: 127.0.0.1 - 07/11/2019 8:52:48 PM
Extension 29920 is registered, contact: sip:[email protected]:5483;rinstance=ac9b0927e045c582, received from: 127.0.0.1
thanks!
