move/copy holiday hours between departments?
ZenMasta
I just updated to v20. I have 2 departments, but the one I thought would be the primary department didn't get any of my holiday hours. Is it possible to copy holiday hours between departments, or do I have to make them all manually?
If you have a group in Version 18 that does not have hours and holidays defined, it will get the Global office hours and holidays that are defined.
Any specific office hours and holidays in a Version 18 group will be carried over to a Version 20 department.
Other than that there is no copy function.
Well, maybe you all should look into such a feature. By the time it's implemented, I won't need it, but it's bound to be helpful going forward. How was I supposed to know which department would get the office hours before migration?
Or maybe have holiday hours work globally but on a department level selection box for which holidays would be used.
Even though there are holidays in the "wrong" department, none of the prompts are assigned either...
Starting over, just looking at my list :/
Steve, thanks for the suggestions, but the requirements are too high (installing web server on windows) vs manually starting over for me.
Reactions: NickEmpireComm
