moving phones to a different subnet
carl313
New User
I have a small office using 3CX hosted PBX that was setup on the LAN behind a firewall. I would like to isolate the phones on a different subnet. The SBC is on the 10.10.xx.xx subnet and I would use 192.168.xx.xx subnet for the phones. I can ping the SBC from the new subnet. Could anyone explain/help me with the process moving and provisioning the phones on the new subnet?
Put the sbc on the same network, you will have to change the sbc server IP address to correct IP address range. check it is registered in 3cx management console
Move the phones to the same network.
within 3cx management , for each extension change the sbc server address - reboot the phones and everything should work
One thing I would ask, as you have a small office why do you want to go thru the hassle and move the phones to another network ?
Reactions: JohnS_3CX
Basically this. And just as an FYI:
- Your subnet will still need internet access, otherwise provisioning, phonebooks, firmware updates will all fail.
- The SBC should be in the same subnet as the phones otherwise expect audio issues and provisioning issues.
- The SBC will also fail if there is no internet access in that subnet (mentioning it in case you were planning on cutting internet access).
Stephan Eusebe
