Moving Servers from one provider to another with different url
jct
I want to move my hosted server from one platform to another. I installed 3cx from the Azure template and chose restore during the install but it wouldn't restore because my current system is on a more up to date version then the template in Azure.
So I installed it like a new install.
I then ran all updates and then tried to restore from the previous backup but it said either the url or the license is different which in this case both are. I want to get this system up and running with a different url BEFORE I bring my old system down. I don't care it is running the free license until I decommission the live server.
How can I proceed without removing the license from my old server and also using a different url?
Thanks!
Nevermind! I figured out you can do that backup without the license and url. Seemed to work now!
Thanks!
GCLANtech
