Multi holidays
VictorC
SOHO User
Hi all, does anyone know a reason you can't make more than one holiday anymore?
If you make one, then go to add a different one it will not let you.
Do you get an error message?
When you add one. Then go to add a new one it says there is one and you can only edit that. Can't do multi now.
Could you screenshot the process?
This error "This configuration contains an existing holiday. Adjust the configuration and try again." should only show if you are trying to add a holiday for the same date that there is already one set.
Best,
KS.
ok, that's what it's doing, can't make stuff for the same date and it looks to default to the current date.
Graham Robertson
