Multi Line TAPI - Help?!?!
David Searles
Forum User
So I have the following scenario, that I'm hoping someone will be able to help me out?
I have (obviously) a 3CX instance running at a customer of mine. Currently running v16.0.4.493 (hosted in AWS).
We are trying to configure some TAPI integration into a CRM type of system that they use called CODAS.
On the CODAS server, I have installed the Multi-Line TAPI Plugin as well as the 3CX App for Windows.
I have a default extension (000) configured on the Windows App.
I have configured the TAPI .ini file to include the other extensions required for the integration into CODAS (using TAPI).
I can get the default extension of 000 (which is configured on the 3CX Windows App) to work from within CODAS, but the additional extensions configured in the .ini file won't work. Event Viewer throws out the following: "The error indicated TAPI error code “TAPI_E_NOTREGISTERED ((HRESULT)0x80040024L)”
Below is the kind of results we get from with CODAS - Extension 000 will connect okay.
So... Does each extension require the TAPI plugin installed on the local agent's PC or the TAPI plugin and the 3cx Windows App? Or just the 3CX Windows app? I think the change I have made to the .ini file on the server has pointed me in the wrong direction assuming everything will be done via that app?
Any advice would be very much appreciated...
Yes, 3CX TAPI works on the client side, so you need to install it where you have the 3CXPhone for Windows configured.
It allows you to specify multiple extensions for the case of a terminal server, where you have many users running in the same server, but each user with their own extension.
Ahh.. that makes perfect sense now - I'll give that a go - many thanks :)
Reactions: edossantos
awan05
